Re: Electrical Problems
Posted by Harold Evans on August 08, 2010 at 14:02:28 from (69.136.4.122):
In Reply to: Electrical Problems posted by Owen Aaland on August 08, 2010 at 08:11:41:
I discovered that my alternator required about 1800 RPMs to self excite. My Farmall H can't even come close to that, even with different pulleys. So, I solved the problem another way. I'm sure each alternator brand is different from mine, but I wanted to show a solution that WILL work on all alternators, if need be.
This post was edited by Harold Evans at 14:14:41 08/08/10.
