Re: Farmall M won't start
Posted by El Toro on August 08, 2010 at 16:20:32 from (74.103.74.58):
In Reply to: Re: Farmall M won't start posted by BDs 41 on August 08, 2010 at 14:50:22:
Hold your hand over the throat of the carburetor and see if there's good suction. You will need a helper to make an attempt to start the engine.
If there's very little suction usually means you have low intake manifold vacuum. Make sure your
intake manifold is tight. Valves not seating well and leaking and worn rings & cylinders can cause low manifold vacuum. Hal
PS: Pour several teaspoonfuls of fresh gas on top one of the pistons. Reinstall the plug and see if the engine fires when trying to start it.
