Re: SW6 Project
Posted by Wardner on August 08, 2010 at 17:53:31 from (4.154.234.208):
In Reply to: SW6 Project posted by DonNOhio on August 08, 2010 at 17:29:41:
Your radiator is probably fine. Have you thought
about re-coring the radiator guy?
I don't trust any of them. It must be the lead. Or
maybe it's the dimly lit and grimey surroundings.
You should do your own diagnostics and let them do
the repair if you are unable.
Get some rubber or cork plugs and a kiddy pool.
You will get a better test if you can pressurize
at the drain plug with 5 psi of air. Don't let the
plugs hit you in the face by accident.
