Re: Cub with noisy clutch
Posted by challenger on August 08, 2010 at 18:38:32 from (71.176.151.86):
In Reply to: Re: Cub with noisy clutch posted by brooksie on August 08, 2010 at 17:23:07:
If you have adjusted the clutch pedal so it pushes in the the three fingers too far, the TOB will make contact with the fingers or the adjusting nuts which will make a loud racket. You may need to adjust the fingers so they are farther out toward the TOB so the bearing does not need to go so far forward to disengage the pressure plate.
