Posted by Bob on August 09, 2010 at 13:06:12 from (69.178.228.68):
In Reply to: Resistor Block posted by farmall706 on August 09, 2010 at 12:04:02:
If you are referring to the one used in the ignition system, it adds resistance to the primary circuit, limiting current to a level that's safe for the points and coil.
Also, it can be bypassed by a connection to a special terminal on the starter solenoid to give a hotter spark during cranking when the starter is pulling down the battery voltage.
The other option is to use a "true" 12 Volt coil which has more primary windings to accept the full battery voltage without excessive current draw.
These usually work pretty well, but DO prevent the use of the starting bypass circuit previously described.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
