Re: 2500A Backhoe
Posted by Owen Aaland on August 09, 2010 at 18:20:35 from (65.165.246.147):
In Reply to: 2500A Backhoe posted by michael w. brown on August 09, 2010 at 10:46:51:
It might be a failed pressure relief valve. It is pilot operated so it will open with just finger pressure even if it is good. There is a small spring inside the middle of the valve that determines the opening pressure. If that spring breaks or debris is keeping to orifice open, you will not be able to build pressure. Usually just swap in a known good valve to see if the old one is bad.
