1066 A/C drain hose RR
Posted by Michael Sheik on August 10, 2010 at 04:48:18 from (199.153.192.254):
Got a cracked one and need to replace and pretty straight forward on removing old one and snaking in new one but is there any tricks to make it easier fishing the new hose up that cab post.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
