Posted by Dave H (MI) on August 10, 2010 at 07:42:56 from (64.12.116.73):
In Reply to: Re: 1947 M carb posted by J.D.HEICHEL on August 09, 2010 at 19:45:29:
You could probably adjust it with the bottom off although I tell you with a couple linkages, a hose and two nuts to loosen, I just pull the whole thing and check the needle and seat for issues too. If you are worried about the needle leaking you can put a little gas in her and lay clean paper under it and watch for drips. Make sure your drain screen is clear or remove the air cleaner hose so any leakage can escape onto the paper.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
