Re: SM Dieseling
Posted by wayne in mn on August 10, 2010 at 10:37:44 from (66.228.242.147):
In Reply to: SM Dieseling posted by kopeck on August 10, 2010 at 09:53:57:
A couple thoughts: first, make sure the idle speed is set low enough (around 400-450 rpm). Idle rpm set too high will encourage "dieseling".
Second, if the problem persists, put the transmission in 4th or 5th gear, apply the brakes, and let out the clutch as you turn off the ignition switch.
