You will need either a separate belt driven pump, or to use the existing system, you will need a "priority flow divider valve". To use the PFDV, which is the most common and easiest way to go, you would plumb it in the pressure line coming out of the pump, with the "priority out" going to the steering and "secondary out" to the existing system. What this does is assure that even when idled down, you do not loose your power steering. It can however rob enough flow from the rest of the system that when idled down, your 3 point or fast hitch will operate slow, or not at all. My 240U will loose flow to the 3 point unless I am at about 1/3 throttle or higher.
I have seen PFDVs at TSC and you will need one sized to your system with probably about 3.5 - 5 gpm to the priority port.
This post was edited by IH fan at 10:12:13 08/11/10.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
