Re: Super-C leaky hydraulic unit
Posted by Brian Schmidt on June 09, 2000 at 21:39:33 from (207.179.196.74):
In Reply to: Super-C leaky hydraulic unit posted by GT on June 08, 2000 at 20:07:57:
I just had mine apart for the same thing. My base gasket was leaking badly. It would slow up when I torqued the 4 main bolts holding it on the tractor. But, it would still leak all over my torque tube. When I pulled the unit off, all the 1/4" bolts were about finger tight. I pulled the plate off and put a very thin skim of silicone sealer then locktighted the bolts and torqued them. This has solved my problem so far. Give it a shot. Only takes a couple hours to do this.
Brian
Post A Followup
: Re: Re: Super-C leaky hydraulic unit
