Re: What is causing this?
Posted by gab on August 11, 2010 at 17:33:18 from (70.104.105.106):
In Reply to: What is causing this? posted by Wilks54 on August 11, 2010 at 08:45:18:
Looks like the crankshaft pully seal to me. The steering gear probably leaks too but I don't think that would sling the oil up on the sides of the engine.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
