Re: F-20 carb
Posted by robgIN on August 11, 2010 at 18:18:46 from (76.208.11.106):
In Reply to: F-20 carb posted by oldiron29 on August 11, 2010 at 16:42:10:
ok that list didn't come out so good, looks like 58 is idle mixture usually about 1 and 1/2 out is close, and 45 in the pic is main jet, 3 and 1/2 turns out is full rich. 1and 1/2 to 2 turns out probably ok for just putting around or light load.
