Re: F-20 carb
Posted by DeltaRed on August 11, 2010 at 18:25:37 from (97.124.212.201):
In Reply to: F-20 carb posted by oldiron29 on August 11, 2010 at 16:42:10:
If after adjusting it still runs too rich,you may have adistilate venturi.take apart the carb,the venturi should have a 3/4-7/8 "hole"(distalate venturi only has 1/2-5/8)
