Re: rpms
Posted by gene bender on August 12, 2010 at 07:03:33 from (67.55.227.196):
In Reply to: rpms posted by CORNMEAL on August 11, 2010 at 16:33:09:
The hex head bolt on top of the goveror and mite still have the deal is where you get top RPMs back it out for more. Maybe the gov assy needs to be serviced. Dont adjust the t5hrottle rod going to the carb or you will get all messed up. Let us know how you get alongm e-mail is open. You can run that engine 200 or so if its in good shape.
  • Re: rpms gene bender 07:04:41 08/12/10 (0)
  • Re: rpms gene bender 07:04:37 08/12/10 (0)
