Re: M magneto trouble
Posted by pete 23 on August 12, 2010 at 10:33:38 from (173.87.8.216):
In Reply to: M magneto trouble posted by William Ransom on August 11, 2010 at 14:18:39:
Do you mean center contact or individual cyl contact points. Center is of course spring loaded brush so directly in contact with rotor. Others may be worn, cap not fitting properly, wrong cap, or timing of rotor like I pointed out before. I have an old cap I keep around that is cut in half so I can observe where the contacts line up as some times you run into drive gears that are not marked or other problems.
