Re: stuck push rods
Posted by rustred on August 12, 2010 at 15:37:05 from (74.198.148.43):
In Reply to: stuck push rods posted by William Ransom on August 12, 2010 at 15:00:42:
are you sure? i have never seen the cam followers stick, and it sure cant be the pushrods stuck. most likely cause would be the valves stuck in the guides. and they would not all be stuck open unless it was cranked over and stuck open from major rust in there. when your cranking it are the pushrods goin up and down? with the starter you would also notice the engine free wheelin, not crankin as it should.
