Re: stuck push rods
Posted by gene bender on August 12, 2010 at 16:04:24 from (67.55.227.196):
In Reply to: stuck push rods posted by William Ransom on August 12, 2010 at 15:00:42:
Your lifters must be stuck up holding the valves open. You are going to have to get them loose. Beter take all spark plugs out til you get the lifters opening and closing the valves or it just aint going to start . Squirt some wd-40 on em and get a rubber hammer to tap the rocker so they will close. There isnt any way the push rods are sticking unless there is a ton of junk in each hole where they are.
