Re: stuck push rods
Posted by Tom Fleming on August 12, 2010 at 17:34:58 from (206.193.253.243):
In Reply to: stuck push rods posted by William Ransom on August 12, 2010 at 15:00:42:
My bet is on stuck valves. Pull the valve cover, and crank it over and see if all the valves go back up. If the rocker's move, but the valves don't, that be your problem. IF the rocker's don't move, then you have a busted cam gear.
If the lifters are stuck, there will be alot more wrong with this engine than just no compression. If it is sludged up (or rusted) inside enough to make the lifter's hang, then the whole engine should be taken apart to search for other "nasty's" inside....................
as always, IMHO.
