Re: 3388 Hydraulic pump revisited
Posted by haymaker421 on August 12, 2010 at 19:05:24 from (75.100.135.171):
In Reply to: Re: 3388 Hydraulic pump revisited posted by RPM1941 on August 12, 2010 at 11:48:57:
I really appreciate your advice, but the hydraulic system operated the tail wheel on the plow and the tips are the same as the disk. I guess the first thing I will try is changing the filters. That is the cheapest thing and you can't change filters too often. Then I will start on the more expensive stuff. But thanks.
