Re: Farmall M won't start
Posted by Marty from MN on August 12, 2010 at 20:18:20 from (174.20.18.7):
In Reply to: Farmall M won't start posted by BDs 41 on August 08, 2010 at 14:22:56:
Is your timing 180 out? If you removed your spark plug wires for painting you may have installed them incorrectly. Not sure how much tear down you did, but if you have suction your valves are most likely in time and with your plugs being dry, most likely a gas problem.
Have you tried starting fluid? If your main jet is adjusted incorrectly that could keep gas from getting to the plugs. Starting fluid should get their either way as long as your throttle is open. If it pops off with the starting fluid then something is messed up in your carb.
