Re: Power Steering on my Farmall D460 has stopped working
Posted by Owen Aaland on August 12, 2010 at 22:44:48 from (63.167.132.70):
In Reply to: Power Steering on my Farmall D460 has stopped working posted by CNKS on August 08, 2010 at 15:06:00:
The 460 has a separate hydraulic pump for the steering. There is no flow divider valve like the 300/350 used. The pump is piggybacked on the main hydraulic pump and has it's own pressure relief valve mounted on the pump body. It is possible that there is debris stuck in the valve and not allowing pressure to build up for steering assist.
