Re: Farmall 806LP engine
Posted by rustyfarmall on August 13, 2010 at 06:17:23 from (209.152.78.140):
In Reply to: Farmall 806LP engine posted by Glenn Hinkle on August 13, 2010 at 05:16:44:
806 gasser would have the same engine, but the LP head would most likely be different.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
