Re: 666 clutch
Posted by mkirsch on August 13, 2010 at 11:51:14 from (64.80.108.57):
In Reply to: 666 clutch posted by Erik Dekeyser on August 13, 2010 at 09:21:20:
THAT is the problem.
The clutch is NOT adjusted by the book, but the TA is. It won't work like that.
You've got two choices:
1. figure out why the clutch isn't releasing and fix it, then adjust everything by the book.
2. fiddle with the TA adjustment until it works right.
With the clutch pedal about 1/2 way out, the TA clutch should be released. The tractor will not roll backwards down a hill with the clutch pedal 1/2 way out if adjusted properly.
