Posted by Old-F20 on August 13, 2010 at 20:35:00 from (71.7.102.46):
In Reply to: Farmall 806LP engine posted by Glenn Hinkle on August 13, 2010 at 05:16:44:
ive got an 806LP. heres what ill tell ya
if you want to replace the whole engine, a 291 and a 263 will bolt in and work. cant mix and match any parts with a C301 since its sleveless.
an 806LP engine is a C301 which is exactly the same as a gasser tractor. HEADS ARE THE SAME!!!! pistons are the only thing different with just SLIGHTLY higher compression, not much
an engine out of a 715 combine will fit, you just need to use the front cover of the the tractor engine. your toolbox will not work if you use the combine engine since the front moutning bracket will not have anywhere to attach. the boss is nonexistant on the combine engine, so no where to thread a bolt in
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
