Re: 806 weak slow hydraulics
Posted by RPM1941 on August 13, 2010 at 20:37:38 from (173.25.70.110):
In Reply to: 806 weak slow hydraulics posted by jdetig1 on August 10, 2010 at 17:49:57:
If you have another IH tractor around or a neighbors try swapping the high pressure cartridge for the rear frame system, 706/1586 all had 1, it is on the side of seat casting, hex plug with numbers stamped in it, just screws in, no oil loss, (engine off), they come in different pressures 1750 psi thru 2500, (86 is under rh rear cab, 2 pipes leading to it), new are pricey for test. 06/26/56 were usually 1750-2000, 66/86 were 2250-2500, it says on plug.
