Posted by RPM1941 on August 13, 2010 at 21:34:45 from (173.25.70.110):
In Reply to: CAMS posted by Tinks on August 04, 2010 at 18:18:35:
The camshaft for the M, Super M, Super M/TA, 400,450, W6, T6 crawler, gasoline engines was all interchangeable, later parts had a LH thread, it came out in the 400/450, same cam gear, good ones were solid hub. This was a parts sub by IH. They had determined on the later tractors with live hyd pump the nut was loosening, and the gear would fail because of the 3 holes cast in hub would shear in web.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
