Re: old piston sleeves
Posted by El Toro on August 14, 2010 at 03:30:28 from (74.103.74.58):
In Reply to: old piston sleeves posted by truckinthumbtack on August 13, 2010 at 20:11:19:
third party image
If you go with new sleeves and have that crankshaft checked for wear and install new bearings it will last another 50 years with periodic maintenance. Be sure to clean that area below where your new seals for your sleeves
are installed of any rust or dirt. When I did this A back in 1975 the sleeve kit was $80.00 from my local IH dealer. The whole tractor was in sad shape, but for $100.00 I shouldn't complain that included the 16-inch moldboard plow. Hal
