Posted by Tom Fleming on August 14, 2010 at 04:05:31 from (206.193.253.243):
In Reply to: old piston sleeves posted by truckinthumbtack on August 13, 2010 at 20:11:19:
The most important thing when re-using sleeves is whether or not the sleeve is egg shaped or "out of round". various oversize pistons and rings are available. If the sleeves have ridge, then use a ridge reamer and then hone. Mic the sleeve, and get the appropriate oversize rings.
there are also other considerations too, like if the bore size is much bigger than the pistons, rings won't cure that.
There are many factor's to consider when reusing sleeves and pistons, but if you take them into account, the engine can run like new if you get things right.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
