Re: What goes in here??? (Farmall 140)
Posted by farmallhal on August 14, 2010 at 05:15:15 from (76.2.187.145):
In Reply to: Re: What goes in here??? (Farmall 140) posted by AL Tractor Pickers on August 13, 2010 at 20:22:23:
After looking at your photos it is evident this is just a nomenclature or description problem. What the majority of folks on this thread are referring too is the crankcase oil breather which is used on some models as the engine oil fill as well. What you are referring too as the breather is actually called the oil bath air cleaner which does have a hood penetration. Most of the folks on this thread were referring too the oil breather for crankcase ventilation and oil fill on the C-123 engines prior to the 140 being introduced which was located in the center of the hood. Your 140's look exactly like mine above the hood. This thread started when someone wanted to know what the cap on the governor was used for and as we developed through this thread determined it was the new engine oil fill on the 140's. Hope this clears this matter up for you, Hal.
