A hydraulic jack between the wheel hub & some place on the side of the rear casting. Use blocking to cushion where the jack rests. Going back in, use a chain wrapped around the axle casting back of the implement mounting brackets. Connect the loose ends to opposite spokes on the wheel. Roll wheel/ tire either direction to bind the chain & pull the wheel in.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
