Re: smta carb frosting
Posted by old on August 14, 2010 at 14:14:54 from (4.245.4.156):
In Reply to: smta carb frosting posted by don from Indiana on August 14, 2010 at 12:49:11:
That is the way a carb works and has to do with the atomizing of the fuel which in turn causes things to get very cold. If it does not happen then the carb is not working as it should and you will have other problems. But yep part of life
