Re: smta carb frosting
Posted by rustyfarmall on August 14, 2010 at 14:16:42 from (209.152.78.140):
In Reply to: smta carb frosting posted by don from Indiana on August 14, 2010 at 12:49:11:
It is a natural effect from the intake air passing through the carburetor venturi. High humidity makes it worse. Actual temperature has little effect.
It isn't just the Ms that do it as I've seen the same thing on just about ALL makes and models of tractors.
