Re: Farmall140 steering loose need help
Posted by Vernon Graham on June 10, 2000 at 22:30:27 from (216.225.11.155):
In Reply to: Farmall140 steering loose need help posted by Dave on June 10, 2000 at 19:54:16:
Check the bottom of the steering box to see if the arm is loose on the shaft.
Post A Followup
: Re: Re: Farmall140 steering loose need help
