Re: 606 front pivot rebuild
Posted by reltor on August 14, 2010 at 15:30:51 from (71.60.191.211):
In Reply to: 606 front pivot rebuild posted by rustyfarmall on August 14, 2010 at 14:20:02:
I think the problem lies in the bore of the axle. It was elongated at the ends and tight in the middle with the current pin. In fact I had to do some honing to get it through. I believe there was more slop with the original pin both in the bracket bushing and in the axle, that combined with wear let everything mate up easily. I am going to turn down the axle part of the pin a little .025-.050" and see how it goes together. It is definitely better than When I got it. Lying underneath I noticed the pin was made out of 1.5" regular old pipe....pretty scary, and pretty loose.
Do you think it would help to lower the weight of the tractor on the wheels when trying to hook up the axle yoke?
Is there any order to attach the yoke?
