Re: smta carb frosting
Posted by Owen Aaland on August 14, 2010 at 20:00:29 from (65.161.86.94):
In Reply to: smta carb frosting posted by pete 23 on August 14, 2010 at 12:49:11:
If the frosting was due to the pressure drop caused by the venturi effect, it would be greater at full load rather than under light load. The greater the load the more air is passing through the venturi causing a greater difference pressure.
