I have an I-6 (Industrial version of the W-6) that has this. The purpose is to stop the transmission gears when the tractor is in neutral to make it easier to shift gears. It's a syncronizer of sorts I guess especially for shifting to reverse and back to a forward gear. I've had my I-6 apart in that area and mine is still functional. It's strong enough to slow the tractor a little on level ground when you push in the clutch. The transmission and such will work fine with out the clutch brake.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
