Re: Clutch Brake on W-12/14
Posted by Haas on August 15, 2010 at 13:49:36 from (75.204.231.91):
In Reply to: Clutch Brake on W-12/14 posted by F-Dean on August 14, 2010 at 20:12:15:
I have an I-6 (Industrial version of the W-6) that has this. The purpose is to stop the transmission gears when the tractor is in neutral to make it easier to shift gears. It's a syncronizer of sorts I guess especially for shifting to reverse and back to a forward gear. I've had my I-6 apart in that area and mine is still functional. It's strong enough to slow the tractor a little on level ground when you push in the clutch. The transmission and such will work fine with out the clutch brake.
