Re: To Whetmj 1948 M with T.A.
Posted by D Slater on August 15, 2010 at 14:42:17 from (184.15.7.202):
In Reply to: To Whetmj 1948 M with T.A. posted by Pete76NY on August 12, 2010 at 06:15:00:
Hi Roy, think you are talking about the gear box that bolted in place of the belt pulley gear box when you say missing gear type. Someone must know who made them but its a secret on YT or I missed the answer.
M&W used the cable shift and also a lever shift type going in the transmission on the right side ahead of the brake pedals with a rod from lever running up above and to the inside of the brake pedals to shift it. Lever had M&W co Anchor Illinois in small letters cast on the lever.
