Re: Help me identify this tractor......
Posted by Red Dave on August 15, 2010 at 15:01:59 from (174.59.227.184):
In Reply to: Re: Help me identify this tractor...... posted by AL Tractor Pickers on August 15, 2010 at 13:56:18:
It looks like an A to me. Look to see if there is a plate hidden under all that grease on the right-hand front corner of the block where the Hydraulic pump would go. There is definitely no hydraulic pump on it now. It would go below the Governor/Distributor drive and be driven off the Cam/Governor/Distributor gear train.
Also look at the top of the torque tube, under the gas tank for a flat spot with mounting holes. That is where the touch control would go.
If there is no plate covering where the hydraulic pump would go, and no place to mount the touch control, it is a Farmall A, not a super.
