Re: Help me identify this tractor......
Posted by CNKS on August 15, 2010 at 16:37:02 from (216.144.104.128):
In Reply to: Help me identify this tractor...... posted by AL Farmall Boy on August 15, 2010 at 13:39:58:
The dealer is wrong, the Super A had hyd from the first model, that is the only difference between the A and Super A, except for a slightly higher compression ratio, and that is not visible. However, since hyd were technically an option, they could have been deleted. That tractor is an A, not a Super A, as there is no plate where the hyd pump goes, and no hyd levers. You will probably find no flat spot on the torque tube for a hyd reservoir, either.
