Re: B-192 Plow
Posted by Haydon Rowe on August 16, 2010 at 02:31:35 from (124.197.13.32):
In Reply to: Re: B-192 Plow posted by gene bender on August 15, 2010 at 04:54:56:
Thanks for that. I'm actually in New Zealand so not sure how the time zones work out.
Your description of the end support brackets makes sense, although I haven't managed to find a picture of one to know what I'm looking for. Are they the same as the brackets on an A-192? (I know a guy with one of them that I could borrow the brackets as a pattern to make some).
Also, what do you think about the mount for the lift handle that should mount on the floor in front of the seat? Is there a right angled bracket needed there?
Thanks again.
