Re: Farmall A trans trouble
Posted by big fred on August 16, 2010 at 10:04:02 from (130.76.32.145):
In Reply to: Farmall A trans trouble posted by Richard Hoewisch on August 16, 2010 at 06:52:51:
My understanding is that the aluminum oil slinger gear is there to move oil up to the little cast trough that directs the oil to the PTO bearing, to lubricate the PTO when the tractor is stationary. If you are not using the PTO, or if you are only using the PTO with the tractor in gear, you won't hurt anything by not replacing it. That said, they are available from several sources, as others have mentioned.
