Re: Finally bought a Farmall C...some questions?
Posted by Bill in NJ on August 16, 2010 at 12:38:01 from (4.248.89.57):
In Reply to: Finally bought a Farmall C...some questions? posted by Faster346 on August 15, 2010 at 17:31:01:
The clutch free travel adjustment is through an access hole at the bottom rear of the drive shaft tube. Be careful. Some C's have a carbon type throw out bearing and adjusting the wrong way or too far can break the bearing. My brother and I are in the middle of a clutch replacement because of a broken carbon throw out bearing. Can't tell if we did it during an adsjustment or it was broken before our work. Be sure the return spring is strong enough to return the clutch pedal off of the bearing. That spring goes from the clutch pedal lever to the left brake/PTO cover.
