Posted by rustcollector on August 16, 2010 at 16:14:42 from (67.142.165.36):
In Reply to: reversing a 400 posted by railhead on August 15, 2010 at 10:45:50:
Reversing tractor involves about a half day of shop activity with a good hoist and knowing what you are doing, plus a transmission cover that will allow putting the shifting forks on the opposite side of the pinion shaft. Some tractors came with a three cornered plate on the cover in addition to the shifter lever. Lever will work, but shifter rails with forks are different. They probably could be cut, turned and rewelded if a permanent conversion. Once you get the cover off the tractor, slide axles out, remove brake pinions and housings on each side, remove the ring gear and differential and swap to the other side of the pinion gear. Be sure to check gear shimming before/during reassembly. I have done this job in the past; if you have questions, email or call. Pretty sure I can find part numbers and pictures. I may have a cotton picker transmission cover off an "M" but not a "400". If you are looking, a low drum picker tractor was reversed in this way. High drum picker tractors had a bull gear housing bolted onto different axle housings, similar to an "MV" tractor, but different.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
