Re: A couple of B questions
Posted by ScottyHOMEy on August 16, 2010 at 18:37:19 from (71.241.195.50):
In Reply to: Re: A couple of B questions posted by bkpigs on August 16, 2010 at 08:54:49:
Correct, they were optional. You could put one on it. The installation is as Athol Carr describes above. For basic parts you'd need the gauge and mounting bracket. On the probe end, you'd also deed and NPT fitting to thread it into the hole you will have to tap and thread into the inlet neck. Many of those necks have a wide flat spot in them to allow for such a hole to be made.
But you may wind up with the opposite problem, wondering whether the gauge is working. That 113/123 block is slow to warm up and with the probe on the lower end, you'd have to work her hard and long to ever see that needle move much.
