MD split question
Posted by BruceS. on August 17, 2010 at 04:57:51 from (76.15.41.217):
MD fixes are (almost) done. Runs great, all leaks fixed except rear main seal when tractor has just been turned off. Does not leak when running. Tractor had not been running for quite a while before I acquired it. Just wondering if regular operation would slow it down. I'm thinking not, but just wondering. The leak is not bad, just annoying more than anything. Probably will have to split.
Question: Can tractor be split without removing belly pump and clutch shaft. It looks like the whole rear end could slide out of pilot bearing, but I'm not sure. Any answers/advice appreciated.
