Hal - A healthy 6 volt system should spin your "hopped up" compression H without difficulty. A few suggestions:
- Swap the battery cables for 00 with soldered terminals. Keep the cable runs as direct (short) as possible.
- Use the highest CCA rated 6 volt battery you can find that will fit the box (I recall it's a "group 1" size)
- Have a reputable starter/alternator shop go thru the starter. A freshened commutator, new brushes and bushing lube will bring the old starter back to life.
- Replace the starter switch - even if the old one looks OK.
Obviously also make sure the generator/regulator is working properly to keep the battery charged.
Good luck - sounds like you've got yourself a nice tractor!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
