Re: Need advice on Super C touch control
Posted by gene bender on August 17, 2010 at 10:17:41 from (67.55.227.196):
In Reply to: Re: Need advice on Super C touch control posted by Paul Shuler on August 17, 2010 at 07:52:04:
Make sure the washer is bent so the nut wont come loose. Worked on on that the gear was loose was able to shim it and it worked just fine.I was able to use a pop can for the shim as it miked out just riteand with nes key. Someone did not bend the washer over thus letting gear get loose. Had another one gear came off and messed up the cam gear when it came off.Bend the washer.
