Re: Steering Bolster?
Posted by john fleming on August 17, 2010 at 10:26:55 from (75.182.108.94):
In Reply to: Steering Bolster? posted by David A. Smith on August 07, 2010 at 16:14:10:
I to did away with the oil and went with the grease route.as there very little movement in the steering to worry about liq.lube grease will work just find just make sure you pack it good around the gears need not full the whole bowl. good luck.(glad you found your problem) former IH dealer mech. john
